JHZR2
Staff member
Originally Posted By: rjundi
Do you have an efficient boiler in the mix? Use the boiler to heat a tank and you get nearly the same efficiency as the boiler itself. These hot water tanks are incredible as losses are something like 1/4-1/2 F degree loss/hour. You also do not run out of hot water.
I run a Buderus (German top notch) oil burner at 93% efficient which is significantly better than any tankless situation running at 75% efficiency. Hot water tanks gas or electric are worse typically for efficiency.
is 1/2 to 1/4 degree loss per hour good or bad? I assume youe implying an "indirect" fired hot water heater that uses a second connection to the furnace used for heating water, right?
I don't see how it is any more or less efficient than an equivalent HE hot water heater (Im assuming that your unit is a condensing, super HE unit, and that there is an equivalent HW heater device too). Unless your point about the 1/4-1/2 losses implies that it is a super-good insulation that is much better than other heaters...
This is really of high interest to me, as though we have radiator hot water heat and not forced air/central air, high efficiency operation of both (and making the best decision) is of really high interest.
