If you want a thick 30 weight run Pennzoil Platinum Euro L 5w30, great oil.Can you talk some sense into me? I recently bought a 2023 Acura Integra, basically Acura's version of the Civic Si. I've got 900 miles on it and am thinking of doing the first oil change this weekend. I just can't wrap my mind around using 0W-20 in a turbocharged engine that will see a lot of high revs.
I joined this site in 2003 and always watched the 20 weight debates from afar. This is the first time I've ever had to run a 20 weight, now I'm conflicted! I know that millions of engines have lived long and productive lives on 0W-20, and that this Honda L15CA may have been designed with 0W-20 in mind. But I also know that I will drive this harder than a typical commuter, and that the EPA requires them to state that only 0W-20 should be used, regardless of what the engineers would prefer, and that thicker oils are specified in other markets that don't have this EPA requirement.
As of right now I'm planning to find a fully synthetic SP rated 0W-30, with the highest HTHS and lowest NOACK numbers I can find. Am I crazy?
Mobil 1 0W40 is a thick 30 essentiallyJump from 20 to 30 should be fine. When you say you are a thickie I thought you are gonna put something with xW-40 in lol
Calculate the frankenbrew mix viscosity with this.I'm a thickie when I want to be. I have nothing against thick or thin oils, because if you're not keep a vehicle to 150K+, it probably won't make a bit of difference. When I dumped my factory fill, I did some blending because I had 5 quarts of 0W-16 that was to go in the Venza. Beings its summer and a Hotter than Haites one at that, I figure It will be OK till my December 1st oil change. See the blend in my signature. I wonder what viscosity I ended up with.
Thanks kind sir.Calculate the frankenbrew mix viscosity with this.
https://www.widman.biz/English/Calculators/Mixtures.html
It probably won't make a difference if you do keep your vehicle over 150K.I'm a thickie when I want to be. I have nothing against thick or thin oils, because if you're not keep a vehicle to 150K+, it probably won't make a bit of difference. When I dumped my factory fill, I did some blending because I had 5 quarts of 0W-16 that was to go in the Venza. Beings its summer and a Hotter than Haites one at that, I figure It will be OK till my December 1st oil change. See the blend in my signature. I wonder what viscosity I ended up with.
...........Or, have you noticed, on cold morning, initial, starts, the the oil "feels" a little, what can I say, "thicker" than subsequent starts on a fully warmed engine?Where are you getting those density numbers?
For comparison, Valvoline Extended Protection 0w20 has a density of 0.844.
Assuming that your decimal is misplaced, there is absolutely no way you can tell the difference between those two oils.
*Also higher expected temps over the OCI you plan to use the oil fill (like summer in Dallas !).Yep, and a lot of manuals say to run a thicker viscosity under high speed and/or severe conditions.
Of course, because if the engine is still warm, so is the oil which means the oil's viscosity is lower............Or, have you noticed, on cold morning, initial, starts, the the oil "feels" a little, what can I say, "thicker" than subsequent starts on a fully warmed engine?
I'm borderline there! Still have several jugs of 0W-40 from my last car.Jump from 20 to 30 should be fine. When you say you are a thickie I thought you are gonna put something with xW-40 in lol
I see no jugs of 0w/16 on the shelf of m walmart. As for 0w/16 qts there...I don't look at qt bottles, I go jug or go home.did some blending because I had 5 quarts of 0W-16 that was to go in the Venza. Beings its summer and a Hotter than Haites one at that, I figure It will be OK till my December 1st oil change. See the blend in my signature. I wonder what viscosity I ended up with.
A strawman question...Curious, are you stating that you have, never, noticed, any, noise, vibration, or smoothness difference in any oil you have ever tried?
I feel more certain after downloading the factory service manual. US models get only 0W-20 no matter what, while Mexico gets 0W-20 through 5w30, ACEA A5/B5 rated oil.
Given the ACEA rating requirement in Mexico, it seems to me that it's not about mandating higher viscosity to make up for low oil quality issues in Mexico. It's more of a government mandate issue in the States.
It is indeed a mandate issue, not that there is a "gubertment" law or rule other than that's the oil used to certify the fuel economy figures here in the US and is subsequently required to be forcefully promoted in the owner's manual (as well as other places). If you read any of the CAFE award letters you will see just how stringently the manufacturer is required to word their recommendations.Again with the 'false equivalence'. In Mexico getting 0W-20 Full Synthetic is both expensive and difficult as it isn't even sold at many of their main outlets. The vast majority of cars get "conventional" 5w30 as their thin oil and everything else is scarce. It's not a "gubertment mandate" issue, it's simple economics explicated by our first world problems of "CAFE" and thick vs. thin narratives for the cars one likely trades-in or sells well before 100K on the odometer anyways....
In a 30% scenario I doubt it will cause any problems. Plus this will only be an issue if it uses oil, which it is not. No GDI here and no turbos. I do like the enhanced quietness of the engine though. No effect on MPG's on this tank which is the first since changing. Waiting for theOkay, i just looked at your sig:
2022 Ford Maverick XLT Hybrid w/Lux pkg-
4 qt Mobil 1 0W-16 & 1.5 qt Mobil 1 0W-40 FS Euro Formula - Motorcraft FL-910s filter
FULL SAPs in modern catalyst? Bold move there Cotton! You're a frankenbrewin savage!
Why not just pour in a jug of Mobil 1 Extended Performance 0w20 and then ash your cigarette once over the fill port and be done with it?
Try 12,000 miles next time.
It's not false equivalency, other grades will work just fine. Or better.
