Syn blends-pretty much more SYN?
Michigan
I simply couldn't help myself...because at 9.99/5qt jug, I couldn't turn down an oil..
Anyways, I picked up a few jugs of Service Pro syn blend in the 5w30, and slightly in debate in what I should do with them (Throw in in the Cobalt with a puro classic for 5k, or use it to change other's cars)
Since it seems some of the other blends are at least 50% synthetic (motorcraft, for example), how safe could one assume that SP's blend would be at 50%?
Besides, for a beater, the Cobalt is pretty spoiled getting synthetic for it's oil changes....(and has had nothing but for the last 33k I've owned it.....)
I wouldn't assume anything unless the oil company sent you their formula and I doubt that will happen.
It's made by Warren Unilube of Memphis.
Does it have the API certs?
Yep.
Service Pro is made by several companies, depending where you are.
Several? What about the mid west/great lakes area?
This concerns me because the the oils themselves could be different...
I don't know about who gets what or where. We are a bulk oil lubricants packager and distributor, and Service Pro is our biggest seller. We have ordered bulk oil and atf from two different manufacturers that I know of, and both make quality products. All Service Pro products are high quality.
So they pick the good stuff then...
