I also disagree with this statement. I switched my '90 Saab 900 (2.0L 16v I4) over to syn at 120k mi. That was 6 yrs ago, & the engine's now up to 185k mi. I fully expect this engine to go at least 300k mi at this point. The way I look at it, it's never too late to start getting better protection into your engine.quote:
I wouldn't switch to synthetic at 140K. Makes no sense to do so this late in the engine's life. If you wanted to get the benefits of a synthetic oil, the switch should've been made 100K ago in my opinion. *Most* 4.0s are on borrowed time per se after 200K anyways. Just stay with whatever oil and filter you have been using and call it good.
I disagree. I might not have disagreed before I owned a Honda but I figure most Honda engines should be able to achieve 200,000 miles with regular proper maintenaince. I have just over 200K on mine and at the following link, that qty of miles is hardly a noticeable achievement:quote:
It's all relative to how you perceive a engine lasting I suppose, but at 200K plus, ANY engine is essentially on borrowed time.
All things being equal,if anything your vehicle should run cooler rather than hotter.quote:
I have a 1994 JEEP Cherokee Sport (4WD/4.0L) and finally convinced myself it is time to spend a few more dollars on better oil. My next oil change will come around the end of the year when I suspect my odometer will read ~140,000.
I was told by someone at a local auto parts store that I should use a petro/synthetic blend for at least the next oil change before going strictly to a synthetic oil as the synthetic oil will have my jeep running hotter.
Is there any truth or value to this suggestion?
My driving is typically rush hour hwy driving, but I do go on short day trips occasionally and will take it off road maybe a couple times a year.
Historically, I have always used Pennzoil lubes and either pennzoil or FRAM filters.
