- Joined
- Dec 7, 2012
- Messages
- 3,579
This Monday, will be swapping in a low mileage (40k) 4.8 Gen III LS, LR4 to be exact into Mom's 2005 Z71 Tahoe. Tahoe was a southern truck and has 240k miles. Last 3 years in New York, oiled yearly, and in great shape.
The 240k 5.3 in it has bad lifters, makes some violent upper end noises and is definitely down a couple of cylinders. I bought this little 4.8 for my Regal, but figured for her daily driving and use, a SBE low mileage motor would be perfect. Plus time was never on my side for getting this project going.
Since the motor is out, will be replacing:
- new serpentine
- valley cover gasket, knock sensors, knock sensor sub harness, knock sensor gaskets
- plugs and wires
- thermostat
- exhaust manifold gaskets with ARP hardware (stock LS bolts love to break)
- upper and lower radiator hoses (did heater hoses and those connectors earlier this year)
- oil pressure sensor
- manifold flange gaskets, studs and nuts
- PCV
- intake gaskets
- oil pan gasket
- oil pickup tube o-ring
Have a local tuner that will be able to flash a 4.8 Tahoe tune to the PCM. From what I've read, a 4.8 will run on a 5.3 tune but use lots of fuel.
This 240k 5.3 uses a quart or so over 5-6k OCI, has strong 40PSI of oil pressure at hot idle and has no bottom end noise. So I will pull the heads, new LS7 lifters, boost cam, pushrods, MLS head gaskets and we will be hitting it with a nice healthy 15lbs of boost and it'll go into the Regal. The rings have got to be worn about perfect for some boost. I'd feel a lot less bad about scattering the guts of a 240k motor versus a young gun. But I doubt that'll happen. Probably will make some good power out of that old girl.
Should be fun!
- new serpentine
- plugs and wires
- thermostat
- PCV
- intake gaskets
- oil pan gasket
Should be fun!
