>My car sags about 3/4 inch. My rear gas struts are leaking due to overload of cargo.
A strut is an assembly consisting of a coil spring AND a shock absorber. KR, if your car is sagging, then the spring part of your strut is worn. Leaking shocks alone won't cause the car to sag. A heavy load can wear out shocks sooner because the shocks (and springs) are working harder over bumps, but a heavy load alone (sitting still) does not affect shocks. Prove it to yourself by removing the shock: the car still sits at the same height with or without the shock. (You can't easily do this for struts, and it also doesn't hold true for special load assist shocks.)
