I also took some pics at a local Walmart. I am not ok with these. The ones I looked at had openings facing both directions. The issue I have is that in the small area I can snap in the photo, many of the slits are fully or partially blocked. So remembering college physics, oil is an incompressible fluid, so flow is directly related to Cv. Thus, the larger the area for flow passage, the more flow at the same Dp and Sg. So one of several things would happen - same flow but higher pressures, maxed out oil pump capacity thus limited flow, or the bypass would always be open to allow the flow.
Any of these choices are unacceptable to me.
Here are some pics to show you what I found. Two different ST models, and a Fram OCD to show what they were trying to build (imagine using the Fram OCD as a positive example). You can really see in the second photo how many of the up facing slits are not open. Even the OCD has some damaged slits.
ST 6607
ST 4967
Fram OCD
ST 6607
ST 4967
Fram OCD
