I was at Walmart the other day to get some Dexron VI for my Saturn. The bottle on the shelf was labeled Dexron VI/Mercon LV. I have always used supertech atf in the past but I was scared off because I wasn’t sure if a single fluid could be licensed by both Ford and GM. The bottle says the fluid is recommended in a GM application, but I want to know that what I’m using is licensed by GM. I have always thought if it says Dexron VI on the bottle, then it is liscended by GM. Thoughts?
