So how many miles did it take to consume 3 quarts?
Try an additive that can possibly unstick the rings, may help. Also, change PCV valve if it hasn't already been done and try going back to Mobil Super Syn in the same grade as previously used. I doubt it's the brand of oil but sometimes changing brands could possibly lead to some consumption. Good luck.Hello, so my Son's 2009 Subaru came with Mobil SuprSyn in it, and didn't seem to have any issue for the 2,000 miles before I did major maintenance. I switched to WM 5W-30 synthetic during the timing belt service at 105,000. Oil level keeps coming up low after 2,000 miles despite adding more. Mechanic says it's probably burning oil at higher rpm. Without going to a thicker viscosity, which synthetic is known to have the best additve package to help retard this issue? Should I go with Mobil 1 and hope for the best?
What car and engine? If EJ253, That PCV is a tough one to get to. It is in the "valley" of the block on the passenger side center. Hoses coming from both rocker covers. Tricky hose factory snap clip hose clamps. Likely have to remove air inlet system from the throttle body.Changing the PCV valve and then reporting back. Seems to be enough folks commenting on that.
I've observed the oil consumption issue as well. Called Mobil tech support. Guy somewhat opined this is not uncommon and will decrease.Sometimes when you switch brands of oil, there will be increased consumption during that first change... that eventually goes away.
Don't ask me how, but I have seen it myself. Or you could have a Subaru with an oil consumption issue. That happens too...
That extreme consumption is not the oil then, as already mentioned it is a mechanical issue of some sort.In my original post I already said that it has been only 2,000 miles since the oil change. And for the record I have NOTHING against the Super-tech brand, as I use it EVERY SINGLE OCI in my other two cars: 1999 Toyota and my 2001 Subaru without issue. I made the switch in the early 2010's after WM scaled down it's shelves of Mobil Superclean 5,000 conventional. Thanks to those with the helpful replies about the pcv valve.
My literal thought. I also suspected they may have used 20w-50 and maybe overfilled it by a quart as well since a 10+ year and 100k+ subaru will do that.What is your consumption rate per 1000 miles?
I doubt the BG will do anything except drain your wallet. The oil consumption is likely the reason the car was sold.
