Originally Posted By: Trav
Quote:
20 grade oils simply do not shear out of grade.
Interesting.
Quote:
The only engine that recommends 5W30 is the ecoboost.
If the 20w doesn't shear out of grade and the 5w30 does why not just spec the 20w for the ecoboost?
Could it be the heat from severe service and heat kill this thin oil?
His driving conditions are harsh, recommending 5w20 leaves him not much of a safety zone IMO.
He is not going to be able to back of the gas to drop the oil temp towing up hill.
I would run PU 5w30 at 5K OCI and sleep better.
Lets see there are UOA's with ecoboost engines that were filled with 5W20, viscosity range was still 20 grade, wear, and TBN retention, were consistent with 5W30's. The issue with the 3.5 ecoboost is fuel dilution. Plus turbo charger. Neither is a factor with the 6.2.
Interesting.
