I recently bought a used 2007 Lexus ES 350 with 55k miles on her. I am about to do the first needed oil change and I plan on using Mobil 1 5w30 with a mobil filter, unless this site shows me otherwise. The manual calls for 5w30 weight. I live in Indiana where it can get cold (single digits in Jan-Feb) and hot (close to 100 in summer). I will probably put about 15k to 18k miles on it per year. My driving habits are about a 30 min commute to work daily, starting off with stop and go and then aout 20 min highway driving. I do make some occasional short trips of about 5-10 miles also. I do NOT drive it easy either. With this car being used, I have no idea what oil has been used before and how often it was changed. I would like to stretch out the changes to as long as possible without being risky. I do have some lifter type of noise from the engine which is somewhat normal for this engine from my research and I did own one before and it also had the noise. I had the dealer do the oil changes on the old one since it was covered by my wifes job. My question is... Any other suggestions for brand and weight of oil? How long should I go before I change again? I plan on subbmitting a sample to Blackstone on the next change. Should I submit a sample of the current oil to Blackstone as well? Thanks.
