Car - 2005 Scion xA automatic w/130,00 miles - not burning any oil, perfect compression in each cylinder, run 20,000 miles per year
History - I have been running synthetic for 30,000+ miles, mostly Mobil 1 5w30 with PureOne filters - 7,000 mile OCI (change filter at 3500 mile intervals) - Blackstone used oil analysis have been very satisfactory
I would like to switch to Amsoil and go to longer OCI (and slightly longer filter changes). Here is my plan:
1) Amsoil 5w30 w/Bosch Distance Plus filter
2) 5000 miles later change out filter w/microGreen filter and top-up oil
3) 5000 miles later (10,000 miles total) send sample to Blackstone for UOA - then (probably) change filter w/microGreen and top-up oil
4) 5000 miles later (15,000 miles total) - send another sample for analysis and probably change oil and filter and begin again (unless UOA clearly shows I can go on simply with filter change and oil top-up)
Comments: I am hopeful that with Amsoil's hefty add pack and the addition of some new oil at filter changes the TBN should be fine throughout. I am changing filters more often than some might suggest mainly because this is a small Toyota engine and it seems more frequent filter changes go far in preventing sludge in these engines (just being cautious here). I am open to suggestions about the filter order here. I had purchased the Bosch filter first, then got a 2-for-1 deal on the microGreen filters before I even sat down to think out this plan. With the microGreen's claimed ability to filter out finer particles, I don't know if using them in a particular order makes a difference here.
I'll gladly accept any suggestions or criticisms, especially if they are reasoned and well-expressed and not just something like, "Amsoil sucks and you're an idiot!" While the latter may indeed be true, it would be nice to know why the former might be too.
