Suggestions for Cleaning bike out
Frankfort, Kentucky
I picked up a bike with about 18.5K miles on it, and it seems to be in good shape. I won't ahve insurance until Jan, so it will be sitting for abouut 2 weeks in the garage. I am going to see if Auto-RX will redeem itself in the bike. The oil needs a changing anyway, so i was wondering about an LC piston soak. I already put a can of B-12 in the tank when i got it home to start cleaning the fuel stuff out, and will probably drop in some FP after this tank is out. Would it be worthwhile to LC piston soak, or just let ARX do it's thing
I would just let the ARX/cycle Rx do its thing. Run at 2 oz. per quart for 1000 miles, with a new filter. What do you have for a new ride?
quote:
Originally posted by drive it forever:
GM top engine cleaner. Comes in a 18oz aerosol can. Part#1052626. Says from the back of can. Removes gum and other deposits from the fuel induction system of gasoline engines, free sticking valves and sluggigh compression rings, purge excess deposits from combustion chamber. Used it on a few engines, and it works. You might want to install new plugs and do an oil change after the process.
I will do the oil change, but don't know about the plug thing. Rather not waste practically new plugs
