Hi all.
I own a '2018 VW Tiguan Allspace 2.0 BiTDi 240HP DSG7, bought slightly used (9 months old/10.000 Km's).
Since day 1, the oil used in the engine was Castrol Edge Professional III 5w30 VW 507 00, as VW recommends Castrol.
The first oil change took place on 18.000 Km's, with no oil consumption noticed and the oil used was the above mentioned Castrol again.
I decided to change the engine oil every year, so in the second year of ownership (2020) I changed the engine oil again, putting in Castrol again.
The next engine oil change is scheduled for the following September, so I started reading about other VW 507 00 oils to be used as an alternative option to the Castrol.
Bear in mind that in between engine oil changes (every 1 year), the mileage driven is between 12-16.000 Km's.
A few days ago, I came across the specs of another VW 507 00 engine oil, the Liqui Moly Top Tec 4200 5w30. When I read them, I noticed that it were better - or at least they looked like better - in my opinion.
So, I am posting them down, for comparison reasons:
Pour Point: -39 °C
Flash Point: 196 °C
Density 851 kg/m³ (0.851 g/cm³) at 15°C
Viskosity Index: 173
Viscosity: Kinematic: 66 mm2/s (66 cSt) at 40°C // 11,6 mm2/s (12 cSt) at 100°C
TBN: 6 mg KOH/gr
Liqui Moly Top Tech 4200 5w30
Pour Point: -42 °C
Flash Point: 232 °C
Density 855 kg/m³ (0.855 g/cm³) at 15°C
Viscosity: Kinematic: 70 mm2/s (70 cSt) at 40°C // 12,2 mm2/s (12,2 cSt) at 100°C
TBN: 8,5 mg KOH/gr
Now, if you lived in an area where the average annual temperature is between (-10 C in winter and +40 C in summer), which one of the 2 above mentioned engine oil would you prefer to use?
Which one will give the best protection to the engine?
Any reviews for the Liqui Moly Top Tec 4200 5w30 by users of it?
Is it worth the chance from Castrol to Liqui Moly, or should I stick with what VW recommends?
Thank you in advance guys.
Pour Point: -39 °C
Flash Point: 196 °C
TBN: 6 mg KOH/gr
Pour Point: -42 °C
Flash Point: 232 °C
TBN: 8,5 mg KOH/gr
