I just purchased a new 2011 Honda Odyssey. This vehicle is equipped with a "maintenance minder" that (supposedly) displays the engine oil's remaining useful life. On the Ford Duratec-equipped vehicle that the Odyssey replaced, I changed the oil every 5K miles using Motorcraft synthetic blend oil and filters. When I bought the Odyssey, I was advised by the Honda dealership that the maintenance minder will sometimes go well beyond 5K miles before reporting that an oil change is necessary, and that it was up to me to decide whether to stick with 5K mile OCIs or trust the computer.
So I have a few questions for the BITOG experts. Assuming severe duty on this vehicle, meaning mostly short trips combined with mountain driving:
(1) Would you change the oil every 5K miles, or would you do what the maintenance minder recommends?
(2) Would you stick with Ford Motorcraft oil on a non-Ford engine, or use something else? Honda says to use a 0W-20 oil, which I've never used before.
(3) Would you go with Honda's OEM oil filter, or use something else?
(4) The owner's manual says not to change the oil for the first time until the maintenance minder says to do it. Can you tell me why this is the case?
(5) I've recently heard it said that the first transmission fluid drain and fill is the most important one. Is this true, and if so, would you recommend changing the transmission fluid sooner than 30K miles?
Thanks in advance for your help.
