Originally Posted By: PaJohn
As the subject says, my car suddenly went from using 1 qt every 4-5k miles to 1 qt every 1k miles. No leaks and it seems to be blowing smoke between shifts, so I'm guessing it's probably the valves. Guess I shouldn't be too concerned as it does have 277,000 miles on it. But the interesting thing is that I was always using GC 0w30 until last oil change when I switched to Castrol 5w40. Theoretically, this change to a thicker oil should REDUCE consumption, so I'm just wondering if it's just coincidence or somehow related. Thoughts?
Oil consumption can be due to a variety of things. Thicker oil may or may not help.
Sometimes, aeration in the sump can cause the oil to expand and raise crankcase pressure abnormally. If that's the case, thicker oil might
increase consumption since it doesn't release trapped air as easily.
It's also possible that the chemical composition of the Castrol Syntec 5w-40 simply isn't as well suited to your application; for example, maybe you have some fuel dilution that GC can withstand but Syntec 5w-40 cannot. Viscosity in and of itself may not be a factor.
My car consumes quite a bit of oil; I've seen anywhere from 1 qt/1600 miles to 1 qt/600 miles. So far, my best numbers have been with oils that were on the thin end of the spectrum but stoutly formulated (Motul X-Max 5w30 and RLI BioSyn SHP 0w-30). The 5w-40s I've tried all did worse. The 5w-40 I'm using now might buck that trend, though, so we'll see...
My brother's Integra, on the other hand, seems to get its best consumption numbers with thicker oil.
As with all things, there really is no way to know without testing.
