I can tell from your long list of cvt equipped Subarus you have direct personal experience. /sarcasmThe Subaru CVT excels at being garbage when mounted behind their gutless four cylinders much less the 3.6. It should be at the bottom of your list for towing, honestly.
A truly helpful **** post, @Rand! I'm sure the OP enjoys your input VERY much!I can tell from your long list of cvt equipped Subarus you have direct personal experience. /sarcasm
to OP: why no suv? or you mean full size suv?
The outback is basically a CUV/wagon not much size difference compared to a forester, Grand cherokee, cherokee, moron-o, roque etc
wow you mean like your post?A truly helpful **** post, @Rand! I'm sure the OP enjoys your input VERY much!
Your car and trailer weigh 1700lbs? It that is really the scaled weight a lot of stuff will move that just fine. Do you have trailer brakes?I need a new vehicle, one capable of towing my Formula Car and trailer (approx 1700 pounds). It must also be garageable, and not an SUV.
Is this weight within the comfort range of an Outback 3.6R for towing?
Maybe. If it is just you in the car and towing the trailer on flat terrain it will be fine. Start adding passengers/cargo and you will find the limits of the factory cooling system, especially if trying to maintain interstate speeds.I need a new vehicle, one capable of towing my Formula Car and trailer (approx 1700 pounds). It must also be garageable, and not an SUV.
we tow a 12,000 lb fifth wheel in the Canadian Rockies year-round with my wife’s 2.5 cvt outback, it is a 2014. 187k miles, original tires and brakes. great car!The Subaru CVT excels at being garbage when mounted behind their gutless four cylinders much less the 3.6. It should be at the bottom of your list for towing, honestly. If you're willing to shop older the 3.6R that used the five speed automatic transmission would probably (?) be more reliable but I'd honestly never tell someone to buy a Subaru and I'm on my second one.
I'd be very nervous about the CVT.I need a new vehicle, one capable of towing my Formula Car and trailer (approx 1700 pounds). It must also be garageable, and not an SUV.
