My younger brother was complaining about hearing a squeaky noise coming from the left side wheel. He drives the Sienna to and from work (a 5-mile two-way drive). So, I looked at the brakes to see if the pad wear clip was put on backward. Welp, that didn't end well. I somehow ended up stripping the lug nut. It just keeps spinning. Does not tight back into place and doesn't loosen out. I am not sure if the wheel stud is spinning with the lug nut or if the lug nut is stripped.
Any idea on how I can remove the lug nut before I give up and take it to my mechanic? I tried putting a smaller socket on the lug and obviously, that didn't work
