Tony,
Looks great! That filter looks VERY Sturdy... Nice job...
Originally posted by Bill Plock:
[QB] Here are some pics of the OilGuard element I recently changed out of my 03 Duramax Diesel after 20k miles of use. Oil was Delvac-1 and changed at 5k-mile intervals along with the full flow filter (Baldwin B1441). Note that the center of the strings are black with soot. Could this indicate the oil is following a spiral path through individual strings from the outer to inner layer of the filter?
Just a theory nothing scientific but I would think if you took at a cross section of an individual piece of string you would find that the center is wound tighter due to the spiral weave ie; a more restrictive surface area, than you would find on the outer edges, therefore the center would offer a higher degree of filtration than the surrounding area.
Soot being very fine in nature would then flow past the holes on the looser outer edges and caught by the tighter center area. This coupled with the fact that the oil is being injected under pressure thru the filter (ball of string) it would collectively work from the most restrictive areas to the less restrictive ones.
Just my two cents worth![]()
BTW I'm using the Oil Guard bypass also. When it's ready to be changed I'll cut the filter open to see if the same thing is happening.
[ April 23, 2005, 08:08 PM: Message edited by: Old Guy ]
The whole unit is stainless,including the head--I made sure of that before ordering from my supplier. There is a nickel plated brass- I beleive- also available but I thought the stainless was the best route to go. I also used high temp hydraulic hoses for complete piece of mind.quote:
Originally posted by Old Guy:
Tony B
Nice looking install you did with your bypass filter. It looks to be a very high quality unit. Is the whole unit made of stainless, or is the head cast?
Tony B
OldGuy,quote:
...Just a theory nothing scientific but I would think if you took at a cross section of an individual piece of string you would find that the center is wound tighter due to the spiral weave ie; a more restrictive surface area, than you would find on the outer edges, therefore the center would offer a higher degree of filtration than the surrounding area.
Soot being very fine in nature would then flow past the holes on the looser outer edges and caught by the tighter center area...
Yes that is what I thought too and that is why I offered to get one for anyone who wanted one. I beleive the all SS are normally around $300 or more from most suppliers.quote:
Originally posted by Gary Allan:
btw- Tony B, that's a great price on a SS canister ..even in that length. That's about the cost of the the 304 body with nickel-brass head. These canisters lend themselves to more mounting options than the larger diameter filters in some circumstances.
From McMaster-Carr:
I've tried to rewind toilet paper once. What happened was it was very time consuming and sloppy. IMO you would need a machine to rewind a TP roll accurately. You know what happens when you use too loose a TP roll in a Frantz - too much oil flow escapes through the Frantz and damages the engine. Why not just use a Frantz 3 stacker or machine your own filter housing? I've always wanted something to accomodate a Jumbo Scott TP roll.quote:
Originally posted by Tony B:
I thought of a great idea! What if we reuse the SS core of the filter and rewind it with paper off of a paper towel roll and create our own cellulose type filters? To make it better the ends would be sealed (dipped) in a glue and allowed to dry before installation.
What do you tink? Will it be better than the cotton string filters?
T
Actually if the frantz has the restrictor hole like it should for the engine oil application no damage is possible even if you did not have a TP roll in there at all. I thought that maybe making a filter was possible using Paper towel rolls--lots larger then the tp ones. Using a lathe or even a set-up on rollers would make it easier to do and keep it centered correctly. But then again after some more thought--my goal is to get a longer mileage filter in the end--that is why I did away with my frantz filter--too often filter changes. So staying with the cotton might be the ticket.quote:
T
Just out of curiosity, Have you tried the frantz canister without a TP roll? The tp roll also restricts the oil. If you remove the tp roll flow rate will increase. How much is a question that I'd rather not answer with my car.quote:
T
Yes, I think these are great filters. I didn't really reach the limit of mine. I installed little guages on taps in the head. New it had 2 PSID ..when I took it off, after a decent number of miles it had 3 PSID. I estimated that a 15k life span was reasonable. Mine was used full flow ..so I don't quite know if that would make a difference. I don't see how it could. I mean it's supposed to trap everything anyway, so full flow shouldn't clog it any more than it would normally.quote:
