Got it... well, I guess Amsoil sees it as a marketing point to list it as both, by virtue of the fact that it contains no VIIs... I like it in my lawn equipment and might use it elsewhere too! Per their site for product ACD:
PRODUCT DESCRIPTION
AMSOIL Synthetic 10w30/SAE 30 Diesel Oil (ACD) is formulated with premium synthetic base oils that exceed both 10w30 multi-grade and SAE 30 straight-grade viscosity requirements for outstanding performance in modern and older diesel engines.
Unlike conventional SAE 30 motor oils, AMSOIL ACD has a naturally high viscosity index and does not contain paraffin (wax).
It has a -36°F pour point and qualifies for SAE 10W, making it an “all season” multi-grade lubricant with a wide operating temperature range.
AMSOIL ACD is formulated without viscosity index improvers (VI). ...
Where these viscosity grades are specified, AMSOIL Synthetic 10w30/SAE 30 Diesel Oil (ACD) provides outstanding performance
as a straight-grade SAE 30 for older two- and four-stroke diesels and as a multi-grade SAE 10w30 in modern four-stroke diesels as well as gasoline engines.
• SAE 10w30 performance without VI improvers
• Cost-effective replacement for conventional oils
• Excellent shear stability
• Outstanding wear protection
• Superior protection over a broad range of operating temperatures
• Extended service life with oil analysis
PERFORMANCE
AMSOIL ACD is recommended for diesel engines and other applications requiring any of the
listed worldwide specifications and gasoline engines requiring API SL, SJ, SH... or ACEA A3.
• API CI-4+/CH-4/CG-4/SL
• ACEA A3/B3, E2, E3, E5
• Mercedes Benz 229.1
SERVICE LIFE
Personal Light Truck Diesel Engine Service
• Normal Service(3) — Up to 25,000 miles or one year, whichever comes first, or longer based on oil analysis.
• Severe Service(4) — Up to 15,000 miles or one year, whichever comes first, or longer based on oil analysis.
Gasoline Engine Service
• In gasoline engines, oil drain intervals may be extended up to two times (2X) the OEM* recommended drain interval (not to exceed 15,000 miles without oil analysis) or one year, whichever comes first.
Replace AMSOIL Ea™ full flow filter at the time of oil change up to 25,000 miles. Replace other brand oil filters at standard OEM* intervals.
TYPICAL TECHNICAL PROPERTIES
Synthetic 10w30/SAE 30 Diesel Oil (ACD) - Revised as of 1/06
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
10.9
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
71.4
Viscosity Index (ASTM D-2270)
141
Cold Crank Simulator Apparent Viscosity @ -25°C, cP (ASTM D-2602)
5165
Pour Point °C (°F) (ASTM D-97)
-38 (-36)
Flash Point °C (°F) (ASTM D-92)
232 (450)
Fire Point °C (°F) (ASTM D-92)
246 (475)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
6.3
Four Ball Wear Test (ASTM D 4172B: 40 kg, 75°C, 1200 rpm, 1 hour, Scar in mm)
0.40
Total Base Number
12.0
[ July 02, 2006, 05:19 PM: Message edited by: Bio-T ]
