Originally Posted By: willistheguy
Oh unfortunately I was being sloppy there and just used the words interchangeably. The main point I was saying is that stuff is tight because it's new
I didn't have time to get reallly in depth with the micrometers but I know the crankshaft was virtually perfect.
Also I should mention the engine has a NEW CAM. So I will be doing the factory camshaft break in procedure (~2000 rpm varying 100 rpm up and down for 20-30 minutes).
The break in procedure you're talking about above is for flat tappet camshafts, your roller cam requires no such break in. Just fire it up, top off the fluids and enjoy.
What kind of vehicle is it going in? Carb or efi? Stock cam or larger? What are the details on the rebuild?
