I wonder how much marketing hype is on the bottle? I sure can tell by price there's plenty of marketing hype. Does any one know if STP is purchasing base stocks and doing their own blending? that's one area I can see the inflated price. $7.49 QRT. I wouldn't touch even with 20% off still 6 bucks per QRT.
Here's what the back label says..
**Helps**
Reduce Engine Wear While Maintaining Fuel Economy
Reduce Harmful Piston Deposits Leading to Ring Sticking
Protect Against Harmful Effect of Rust and Corrosion
Maintain Cleanliness of Critical Turbo Components
Prevent the Negative Effects of Ethanol/Water in Oil that can lead to Engine Failure
I like the last factoid, wonder how beneficial that is for Direct Injected?
STP SYN
Looks good on paper if anyone knows where one can pick this up cheap give me a head up.
Thanks
**Helps**
STP SYN
Thanks
