Stop wasting your Money!!!
I have always been amazed at people changing the oil at 3k or 5k. Had a 1995 Toyota Camry v6 ran Mobil 1 synthetic 10K oil changes at 200k my front valve cover started to leak when I took the cover off the inside looked brand new. Car never burned a drop of oil. Now I run Mobil 1 in my 2015 F150 and using Mobil ! EP 20K have 80,000 so far and no problems. Do you know how often 20 million dollar jet engines get the oil changed?
Did you know that $20,000,000 jet engines consume a lot of oil during operation?
I'll toss one in here for the OP, Third Generation Prius can have an oil consumption problem once they get near 100K miles. Not all of them but it seems that those individuals who think 10K mile oil changes are the way to go seem to be the ones experiencing the most problems. Toyota changed the OCI from 5K to 10K miles shortly after releasing the 2010 model.
I have 94K miles on my 2010, it still uses ZERO oil (0W20) between 4500 mile / 6 month oil changes.
do you know a jet engine is NOT an "internal combustion engine"? No? That's what I thought....
In general, I would expect that most if not all bitog members are guilty of changing their oil on the conservative or early side ... Townies or not.
if buying a used car, ask them if they are a bitog member. They should add that info to Carfax.
In the present state of affairs, the OP's analogy - Jet vs ICE engine - should come as no surprise. Some entities go as far as being unable to tell their gender. Take it FWIW.
ICE compared to a modern jet turbine engine is worse than comparing apples to oranges, it is even worse than trying to make orange juice using only apples. But everyone here on BITOG knows that.
The way different engines beat up and degrade oil varies widely, and even the amount of protection different engines require from oils also varies, add to that the different ambient temperatures from artic to desert, durations of trips from always short trips to always long trips or the average engine that sees a mix, loads on the engines such as towing, empty, city, highway, hills, flat-land, non-demanding driver, lead foot, miles on the engine including the sensors that the engines electronics use to tune the air to fuel mixture and timing, type of fuel metering system and age and performance of those parts, turbo or NA, compression ratios, range of RPMs it runs at, TAKE ALL OF THIS INTO CONSEDERATION AND EVEN COMPARING SOME ICEs TO OTHER ICEs IS ALMOST LIKE COMPARING APPLES TO ORANGES. You can not make broad statements about how long everyone should run an oil change interval with all the different types of gasoline internal combustion engines that are in use now days and all the different conditions they are used in.
  • Like
Reactions: MM8
What is a Townie ? Excuse my ignorance.
Definition of townie
informal
: a native or resident of a town, especially : a permanent inhabitant of a town as distinguished from a member of another group (such as the academic community)
In the world of BITOG, it is one that has been around here for many years/posts, and watches the 'newbies' ask the same questions over and over.
Instead of 'get of my lawn", its "get off my forum".
W
A made-up term that some have used to describe long-term members. It is intended to be derogatory.
With that, it's lock time. This thread started out with trolling, was posted in a the wrong section, has devolved into bickering, and bashing of the forum itself.
