Not sure. Here are some approvals. ( not that they approve the OCI.)Does it meet the Ford spec for PSD?
For your first post, you sure didn't make a good impression.I have always been amazed at people changing the oil at 3k or 5k. Had a 1995 Toyota Camry v6 ran Mobil 1 synthetic 10K oil changes at 200k my front valve cover started to leak when I took the cover off the inside looked brand new. Car never burned a drop of oil. Now I run Mobil 1 in my 2015 F150 and using Mobil ! EP 20K have 80,000 so far and no problems. Do you know how often 20 million dollar jet engines get the oil changed?
I change the oil on our cars. Had a 2008 Cobalt that was short tripped through winter, I had put in PP 5W-30 in the fall. Changed the oil in April at after about 2500 miles, the oil filter was so sludged, it had collapsed.To each his own. We all know the 3000 mile oil change is usually a waste.
It does indeed meet the Ford spec for Powerstroke.
In Tokyo early this year I watched a tech open the port on a GE90 … he had a little box of MobilJet ester stuff … pulls out little bottles and topped the engine. Now I feel connected to that moment and will do less to care for my over priced Jeep …Do YOU know how often jet engines get their oil changed?
Or the type of oil they use and the size of their sumps?
Or the COST of an oil service?
Or the rate of oil consumption?
I don‘t even understand his points. The 3k oil change business has faded … in fact, when I (unplanned) used Jiffy early this year they asked me what OCI to put on the reminder. I have FCA, Ford, and GM products and the OLM’s and OM’s take you 7k-9k … So, the carmaker‘s numbers …The fact that the OP just stopped, dropped and ran tells you all you need to know about the seriousness of this thread.
You mean they keep the used oil from customers (I'm guessing customers that religiously change at 3-5k) and use it on their vehicles?I know a worker at a quick lube place, they save the 3K and 5K oils to use in their cars, and do 3 or 4 changes per filter. He drives about 300 miles a week, and appreciates the savings. His car has 300K Plus
Rod
It does have Ford spec on the label
