I have a Stihl FS-45 weedwhacker, probably five or more years old. I mixed pump gas at 50:1 for its first season but have run ethanol free Tru-Fuel 50:1 since then.
The machine sat idle for all of May in need of a new cutting head. The new cutting head was installed on Memorial Day (31 May) and I tried to fire it up. There were 2-3 ounces at most of fresh fuel in the tank. It would start and then stall out immediately as if only the primer charge was getting there. This went on for a while, so I added more fresh fuel but no joy. I forgot to mention that the exhaust screen was clean.
Next I added a little bit of Sea Foam. Maybe a half an ounce? In any event, the machine continued to start but would stall out on any touch of the throttle. It would run 3-4 seconds at this point. I added more Seafoam - maybe two ounces at most. I let it sit for three hours and tried again. At this point it would run continuously at full throttle but any slight leaning of the motor or touch of the throttle would cause it to stall instantly.
Tonight I went out an gave it another go. That's five days of soak time for the Seafoam. It ran normally with full throttle response and no stalling. This isn't a product endorsement, but Seafoam does appear to have solved my problem.
