Stellantis Propulsion Engineer Interview About Their New Hurricane Engine
Just checked, they take the same squirters (392/6.4L and 6.2L) so would just be more volume through the same orifices.
Specifically regarding the Demon:
What are your oil temps like? Do they stay close to coolant temp or do they get a fair bit higher?
Both my 6.2 and 5.7 have the same temps....hovered around 220 once fully warmed up and driven normally for a while.
The 6.2 saw 250 at times when driven hard. Don't really drive my 5.7 hard like the 6.2.
I drive my 6.4L pretty hard but can't really get the oil temps up to that level, which is expected, you've got like 525HP on me, lol.
Anyone know if there's a difference in oil pump relief pressure between those pumps? The one with higher output also have a higher relief pressure?
I don’t think there is. I see the same pressures at higher RPMs between my 5.7 and 6.2. Idle pressures are a different story.
He talks about oil around 22:20. Amongst other things, he talks about the normal Hurricane calling for 0W-20 and the High Output calling for 0W-40 when both engines are essentially identical.
Makes me even lean more to filling my '23 Ram 5.7 with 5W-30 instead of 0W-20 that it calls for.
Engineer Deep Dive 3.0L Hurricane
That’s what I would do if I were you and is what I do.
