Cranking to try and "prelube" it is such a horrible idea.
You have minimal oil pressure when cranking so all you are doing is increasing wear on the bearings. We are about decreasing startup wear not adding to it.
There is NO benefit to doing that and a lot of harm I can see.
Charge the battery, check the oil, turn the key and start it. It is that simple. Let it idle a bit then just drive it gently to the gas station.
A bottle of techron isn't a bad idea either.
