I need to start the Escalade after sitting for about 9 months. Should I pull a fuse like fuel pump or fuel injection so it cranks a bit and gets the oil flowing. Or just start it up?
No need to disconnect anything to be able to crank without starting. Just hold the gas pedal to the floor while turning the engine over. That tells the computer to turn off the fuel injectors cause the driver thinks the engine is flooded. Personally, I wouldn't worry about it.
No different than doing an oil change without pre-filling the filter.Should I pull a fuse like fuel pump or fuel injection so it cranks a bit and gets the oil flowing. Or just start it up?
Unless the fuel has gone bad. Sniff test. Even if a car will run on bad gas, it should not be done.I bet it fires right up quick with no issues.
Why? Running a car on 8 year old gas currently.Unless the fuel has gone bad. Sniff test. Even if a car will run on bad gas, it should not be done.
On your car it probably does not matter.Why? Running a car on 8 year old gas currently.
On ANY car it probably doesn't matter.On your car it probably does not matter.![]()
