EuroVan fuel pressure really high
Pacific Northwest
So I'm trying to diagnose an issue with my brother's Winnebago Rialta which is built on 95 EuroVan chassis. It has the gas 2.5l 5 cylinder engine.
The condition is an intermittent crank, no start condition. It will sometimes start, but die soon after, especially if you try to drive it. I narrowed it down to fuel delivery. Spark is nice and hot and a little toot of ether make it fire right off until the either is consumed. After sitting a while it will start and idle again. Eventually.
When I got it, the battery was for knob dead, but it charged and the alternator is putting out a nice 14.4V.
First I tested the fuel pump relay because those are supposedly a common failure point, but it checks out good. When I apply 12v across the control pins, I get an audible click and 0 ohms across the power pins. It doesn't get hot while running, and I see 12v on the positive control pin with the key on.
Second, I pulled a fuel line off at the engine and rigged up a fuel pressure gauge. To my surprise, I'm seeing 86 psi at both fuel line at the regulators The spec that I found online says 36 or 40 psi.
Anybody have any experience with these? I'm starting to think it's not fuel delivery.
I finally found the pre-OBDII ports in this thing and retrieved a single code: P1344. Ignition Coil Power Output Stage 2 Short to B+
That's near dead head pressure, Guessing no electronic fuel pump speed control?
Bad regulator or a restriction on the return side?
Not remotely familiar with Volkswagens!
Me, either. I'm not even 100% sure I got the pressure from the right place or the right way. There's no schrader valve to measure from. I had to hose clamp my pressure gauge inline at the rail.
I did manage to get the blink codes and got 1344 which is "ignition coil power output stage 2 short to B+." I'm tempted to throw a new coil at it.
High FP like that can cause the engine to flood....But would also run pig rich when it does run.
As long as you are testing inline or "Tee-ing" into the system....Dead Head testing a fuel pump has it's place though.
Thanks, I got it sorted a while ago. I was measuring the fuel pressure at the wrong location. The ultimate issue was the pickup in the distributor was bad. My brother finally mentioned that it had died on him earlier when he spilled coolant on the distributor. Why VW chose to put the coolant expansion bottle right above the distributor on that vehicle, I can't guess.
