'88 Suburban, 305 V8, 123,000 miles. Fuel pump went out last summer and was replaced. Fuel filter replaced at the same time. Shortly thereafter ignition coil went out. Replaced with an aftermarket unit. New cap, rotor, plugs and wires.
The problem is that the truck has been sitting in the parking lot since August. It was started twice in that time. Naturally, the battery went dead and was replaced back in December. Yesterday, the engine would barely turn over, so the battery was charged up at the parts store. Now the engine is cranking just fine, but it won't catch on. There's spark and fuel.
Is the problem simply with the stale gas that needs to be replaced, or should I be looking at spark strength, or anything else?
If the gas does need to be dumped (3/4 of a 25-gallon tank) what is the proper way to dispose of it? If not, can I just add some fresh gas and a healthy dose of FP and some starting fluid and just run the old stuff out?
Thanks.
Thanks.
