- Joined
- Oct 25, 2024
- Messages
- 14
The car cranks but no start. Battery light shows on but I just changed the battery. Basically when I turn the car on it blinks maint required, while battery light and the oil light stays on. Gas seems to enter the engine but then there’s no ignition . Does oil cause a no start? The car also turned off under load! Either a guide to diagnose it or a suggestion would be great! I changed the crankshaft sensor, starter, battery, an ignition coil was obliterated and replaced spark plugs and the coil! Still no ignition!
