- Messages
- 671
- Location
- New Jersey
Hey everybody,
Got a difficult problem here. 2004 Toyota solara 2.4l auto. One day it would not start. No lights or radio, wouldn't even crank.
Checked the starter, brand new (under warranty) and tested working. Brand New battery (also under warranty). I've tried cleaning all the positive and negative connections that I can find on the car. I used a multimeter and 12.7 volts to the starter, relay/fuseboxes and alternator. Battery was charged with a battery tender charger overnight. I changed the starter relay but no luck. The only spot that I found was drawing some power at 3.2 volts was a wire that goes from the engine block to the frame. Tried changing that wire too and cleaned the connections. Still nothing. Still pulling 3 volts.
Now when I changed the battery cables from the positive battery to starter and negative to the transmission, and it started once. I thought it was fixed. When I put everything back together the car wouldn't start again. I took everything off and put it back exactly as it was when the car started and couldn't get it to start again.
With a charged battery, the lights and radio turn on as normal in the start/acc position and are fine. I hear a click as I try to start it, which may indicate the ignition is fine. As soon as I try to actually start it, all power cuts out like there's a cut off switch. (Security system is the original from the factory). I have to wait about an 30 minutes or so to try again. And the same thing happens. Also tried the second key. Security light turns off with both which means the system is recognizing the key.
At a loss as to what it could be. I'll be testing all the fuses tomorrow; none of them look like they blew from visual inspection.
Anyone have suggestions? I've never come across something like this.
