Yeah, solenoid get confused with relay all the time. To me, a solenoid is an electromagnet the when energized provides a motion to actuate something and a relay, while similar, is used to move electrical contacts.
Your starter has a solenoid on it to move the bendix gear to the flywheel.
The starter relay on the fender is often called a solenoid.
Anyway, for your problem I would be looking at the ignition switch. It's a spring loaded slide switch mounted on the lower steering column at it does all the Start/Acy/Run electrical work. The ignition key cylinder just has a rod going down to move the switch.
These switches can get gummy and not slide well or the internal spring is weak or broken. Over time this causes the plastic hole/slot that the linkage rod fits into to wear and become sloppy. This explains why the starter mode is not fully disengaging and can also explain why the dead battery. You pull the key out but its still partially in RUN mode and powering the ignition coil. The switch could just be old and burned up a bit causing the internal contacts to slide around. Look for scorching or melting on the switch and harness plug.
This switch may just be loose or need adjusting by sliding it up or down on the column.
A bent or stretched linkage rod from the key to the switch will act like a shorter or longer rod and do the same thing.
My money is on the switch.
