Originally Posted By: Yuk
Wow a lot more interest in this topic than I expected!
mechtech2,
Based on what I know I'm lean towards your fix as the right one. Why do you suppose other people think it's the solenoid? Also, I thought that the solenoid for my van is on the starter, are you able to tell me where it is? Last night no amount of hammering on the starter, or dis/re-connecting of the battery corrected the problem. The circuit remains open today and would produce mega arching and a cranking starter if I tried to connect the battery right now.
If it was the bendix, the starter wouldn't engage in your above scenario, it is either the solenoid or the ignition switch. Most likely the solenoid is stuck, as this is the most common source of this issue.
I grew up around antique boats. They ALL had these starter solenoids that would eventually stick and cause what you are experiencing. It is common.
To find the solenoid, follow the fat wire coming from the battery. If ends on a cylinder-shaped thing with two posts on it, that's your starter solenoid.
