Just installed the Motorgaurd on my 2004 Ford with the 4.0 OHC engine. I used the PermaCool universial adapter and mounted the filter on the fender about 13 inches above the adapter. Now it seems that the oil pressure gauge takes about 1/2 or 3/4 second to move up. There is also a very short rattle that was not present before. I have read about drain back from the bypass filter, is this the time delay I see on the oil gauge? I have installed two other Motorgaurds but used a sender "T" to supply the bypass, no problem with pressure or rattle. How can this be corrected? How about moving the restrictor to the input feed line to allow the bypass to fill slowly and pressure the engine quicker?
WDP
WDP
