Spring 2026 Delo Rebate
The 400 xle sb is a tremendous value especially when on sale and rebate.
Chevron really does set themselves apart for customer care on the technical side and their rebate team. Though, I can’t say anything bad about Shell either.
And their rebate came fast. I purchased and submitted on May 29th. Had $50 rebate on June 11th.
13 day turnaround. Mobil should take note. (I didn't do Delvac this season due to their turnaround. I did do Rotella, Delo, Pennzoil, Castrol, and Mobil 1. Sheish.)
Indeed. They communicated quickly and approved with the checks being cut in less than 10days on my end.
You dodged a bullet by not submitting to Delvac. I’m not sure how Mobil accepts that many who are denied, end up using another brand. There are respectable offerings elsewhere that meet A40/GT or VDS 4.5. I certainly did my part letting them know the experience I had will be shared with one of the largest PCA clubs all around. Sure, rebates can generally be a distant thought regarding oil choices, but not when it comes to a company misrepresenting on a blatant basis.
I have no problem putting Chevron, Motul, and even Shell in the 911 or diesel tow rig when the change is due. I told them just that!
I did submit Mobil 1 for Mobil 1 FS 0w-40, as I use it in our toyota. It's the last one of the five I'm waiting for.
I just skipped M-Delvac because I just wind up selling it on FBM anyway, as I did with the Rotella, Castrol, etc.
Makes sense. Mobil runs the same team, they just really, really pushed against many not even posted here for the larger ticket Delvac items. Who knows why as there are as many theories as chocolate chips on a cookie.
I believe in capitalism.
I so happen to use what I buy. On the odd run and a changeover of 5w-40 to 15w-40, I was selling my gallons of T6 5w in 21/22 for $40gal.
My Castrol rebate came from Arrowhead and was super speedy. Mobil can't blame their chosen processor.
That’s were you’re incorrect. I’m not sure if you understand how companies that are contracted to represent one or more entities work. Each has a set of terms that must be abided. When those terms are not held or modified unbeknownst, then there are issues. As is the case here with the arrowhead representing Mobil and their products.
Stating that Castrol utilizes the same company has absolutely NO bearing on that of Mobil. I’m surprised that you would insist such.
Let us stick to that which we know. After all, guessing has no qualitative analysis…….
I understand exactly what I said.
Clearly Arrowhead can a quick rebate. Mobil can't blame Arrowhead. Mobil's contract/arrangements are on them. If mobil requires (for example) their processor to hold all rebates 60 days and deny 20%, that's their call.
I know both companies have used the same processor. I know one has repeatedly had poor results.
