- Joined
- Jul 11, 2014
- Messages
- 4,118
I don't use or recommend any thread lube on a newer spark plug. It will cause you to overtorque. Could also cause corrosion with the different metals.
My recommendations is to work on a ice cold engine. Just ratchet that plug out and install the new fancy plug, torqued to spec and don't worry about it.
Autolite, Bosch, Denso, NGK.... doesn't make a difference. I've used them all in Toyotas. The only thing I look for is the double-fancy-metals. They'll pretty much last forever, or the next 100k.
