Turns out the plugs I got the from the dealer were actually NKG plugs, not Densos.
In looking it up on the NKG site, they recommend NOT to use antiseize with their plugs?
https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
Does anyone have any experience with this?
Also, should I be concerned about cleaning out the threads of any penetrating oil that will likely be left on them after I get the plugs out? Would a blast of compressed air be sufficient?
Of course they don't recommend using it, they would be beyond insane of they did. The use of antiseize lowers the torque and if used improperly can cause misfires that could destroy the cat which would open them them up to lawsuits not only from consumers but the EPA.
Who is installing them and the amount being used is beyond their control so it is safer to say rely on the plating.
The plugs are plated why do I need antiseize?
Depending on where you live plays a big part in the answer, if you live in a warmer climate like down south then probably not on plated plugs but if you live in a 4 season climate you have conditions they don't.
Cold starts in low temps cause a lot more fuel and moisture in the cylinders together with combustion heat creates a corrosive environment, plugs threads corrode from below not above where there is a seal either in the form of a gasket or taper.
Some engines are more prone to this than others eg old Ford Kent engines were so bad if you didn't remove early and antiseize them there was a very good chance you would end up puling the head to get the broken ones out.
Aluminum head(s) further exacerbate this issue as the aluminum expands many times more than the steel plug allowing even more junk up into the threads. The thing is with antiseize you need to reduce the torque (20% less is safe) and don't use too much, make sure you don't get any on the firing end just a very small amount on the treads.
I have used antiseize on every single plug over the last 50 years and never had one cause a problem either being removed or misfire but ones I didn't service I have had a lot of them (yes even the plated ones) stuck so bad I was lucky to remove them
Apologies for the long winded post but this subject demands an explanation.
