Can you please explain what MIM firearms parts are? And, are they better/stronger than most firearms parts?
Thank You.
Certainly
In layman's terms, its like making jello (for a visual effect)- you mix sintered metal ( powdered) with a binder ( to keep from clogging during the injection and allowing for flow just like water in a mud slurry) then bake in a mold.
Its superior to investment casting because the injection pressure ( almost always with vacuum on the end) makes for more uniform mold surface covering and the melting carrier allows for less porosity.
One big thing is that have the least "waste" in terms of machining ( a big financial incentive)
Better/stronger- this is debatable because "better" is hard to quality and is a moving target. "Stronger" is application specific and also is a moving target.
The inherent weakness of any MIM part is that is like any other casting in terms of there are limits to density, heat treatment, alloying and other things. So, parts like housings, lifters, some cams and parts not subject to stress or high shock loading can be made "strong enough" ( MIM will NEVER "equal" the strength of forged alloying but its not necessary that it does because that is often several times stronger than the application requires anyway)
The big thing is small parts (If I could afford the process I would use it myself in my retirement business because I am encountering the same thing)
"small parts' take more jigging and machine time and more waste than any frame, slide or other receiver. They are often impossible to nest and gang machine.
Here's an experiment- go to McMaster and order a piece of 3/4 key stock say 36" long.
Now get a manual mill ( or CNC) or even a hand file or Dremel ( just to illustrate the point in terms of all the machining operations)
Now make me just 1 "28" vent rib for the shotgun of your choice OR make me 30 sight kits ( front and rear) for your favorite pistol.
That will illustrate the value of the MIM process for parts that CAN be made that way.
Hope that helps
