Southern Home Indoc
Alabama
Im relocating from North Dakota to Alabama at the end of the month. Big change from a climate standpoint, and I'm not at all familiar with certain aspects of southern living to include bug/pest prevention (very minimal spiders, beetles, snakes, etc. up here) and generally very different home construction.
I am under the impression that routine spraying around the exterior and/or interior of the home is going to be needed, and like all of us I prefer to DIY whatever I can. Any recommendations on product, frequency of application, or anything else? The new place is a 2024 build ranch on slab, so no crawlspace or anything if that matters.
On the build side, it has a gas tankless water heater mounted externally and a gas furnace in the attic. I was very surprised to see a gas furnace as I was fully expecting all places to have heat pumps with aux heat. For the tankless heater, do I need to be ready to do anything to protect it if it drops below freezing in the winter? With the air handler in the attic and a longer condensate drain line I imagine I'll have to flush that out once in a while...I'm used to furnaces in the basement with a 3' run to a floor drain for the line so I've never had to worry about it.
Thanks in advance for the sage advice 😁
Welcome to the south.
You are probably right that you are going to see many insects. I live in the deep south and use "Ortho Home Defense" to control insects around and in my house. It is available at Ace Hardware. You will just have to get used to "Love Bugs". They swarm twice a year and are a real pain. They splatter on your windshield and the front of your car. There is no really good method to handle them. You will need to wash them off often. They are acidic and will damage the paint if left on.
Your HVAC will have a condensate drain that will need to be treated by pouring a cup of bleach in it. I do mine about every 60 days during the summer. There are probably other methods but I have used the bleach and it works OK.
Mosquitoes can be a problem in some areas.
My Wife is OCD on bugs.
Wife uses a battery-operated retail product (see picture below) for pest management when I am out of town working.
I use a Milwaukee sprayer and a concentrated pest management product (see picture below). The difference in time, efficiencies, coverage, and cost, make the Milwaukee sprayer a more cost-effective solution over the long run. The Milwaukee sprayer makes pest management oh so easy.
Another vote for the Ortho Home Defense. I use a 50-50 mix of concentrate & water in a simple pump sprayer and apply to my home's perimeter every two months while hitting the doors (front, rear, and garage) monthly. Once dried, it seems relatively unaffected by rain (although I usually re-apply after heavy rain).
Corpus Christi can be very buggy with a lot of cockroaches. The vast majority of my neighbors use commercial pest control services. We've had virtually no issues in over three years. If a random roach gets into the garage, it's usually on its back doing the funky chicken shortly thereafter as a result of the Home Defense. Good stuff.
Diatomaceous earth and boric acid powder are good for areas where it does not get wet. Bengal roach spray is great if you are in areas with roaches. Several times a year I have pest control places coming by wanting me to sign up for treatment plans. Those are expensive and unnecessary. If you keep your place clean and avoid leaving out food an water sources, that goes a long way to keep out bugs. I have also used Sawyer Permethrin that I use to keep ticks off me for hunting in areas where I have bug ingress. That works well too.
All of the above, and you will need to deal with termites as well. You can choose from liquid barriers like Termidor, or bait stations. Do it yourself is possible, but labor intensive for the liquids. Liquids require a 6" deep trench around the perimeter of the house that you flood with the liquid. Bait stations just need holes bored every 10'-20' around the house. I had a local company install bait stations. Most termite companies offer a warranty that includes repair of any termite damage. Homeowners insurance doesn't cover termite damage.
Sounds like as long as I am using the proper frequency for application just an exterior spray will work then as opposed to hitting the interior side of exterior walls as well?
I would go straight to the pro stuff and skip the highly marked up stuff at the big box stores.
Get Bifen XTS. Best stuff I have ever used and works on pretty much everything, from wasps, spider to ants and beetle bugs. I bought a quart about 5 years ago and a still have 1/3 left. It’s highly concentrated and you use very little for each application. Lasts about a month to two months in the dry season.
I’ve never seen wasps come back to a sprayed nest. I had nests up high where I could not knock them down hang in there for years, but no wasp ever came back. With other products I’ve seen them coming back after few months.
Not sure about your state, but I had to order it from Walmart, as Amazon doesn’t deliver it to Texas for some odd reason.
Sweet home. As for your tankless, make sure all the pipes are professionally wrapped with insulation on the inside. Follow manufacturer's service recommendation. Pro tip: Don't order unsweetened iced tea at restaurants, you will give away you ain't from around there plus most places don't even offer it. Also memorize the names of the head coaches and starting QBs for both Auburn and Alabama. Trust me, it will come in handy.
  • Love
Reactions: GON
Atlanta resident here. I spray my outer perimeter 2x/yr with a perimeter with Ortho Home Defense bug/pest killer that is available at Home Depot. It takes me all of 10-15 minutes . The only bugs we deal with inside are ants when it gets very wet in the summer. Argentine and carpenter ants. A couple of liquid baits takes care of the little Argentine. The carpenter ants (usually around 10 or so over a 1-2x period get terminated.
You won't have to worry about termites as the soil has been treated by the builder. Get a copy of the Termite bond.
Fire ants occasionally pop up in the yard. I kill them with a granule which you water into the colony. I bought a small bag 25 yrs ago and have probably used half of it. So it's not really a huge problem where I live
Flying bugs are another thing. Mosquitos, moths.
One way to help keep bugs away is to keep the landscaping off the sides of the house. Bushes should be around 3 ft from the house.
I don't consider my resident brown widow in the garage a pest.
HVAC condensate line: You can throw in a tablet or 1/4c vinegar every month.
Thanks, meaning insulation on the pipes as they head into the wall from the externally mounted heater? I like sweet tea, no problems there. War Eagle!
All very helpful, thanks. Monthly cleaning of the line seems pretty often?
I'm in the Milwaukee ecosystem so will consider this. I see they make M12 and M18 versions, although the M18 looks like overkill so I'll probably go M12. Multiple tanks for using it with lawn product as well as bug product would be nice.
My HVAC guy said 1/4 cup every month it runs. I just pour it in and go. I don't bother with sucking out whatever is in there. Lived in my place for 26 yrs and had a clogged line around year 10 because the bi-metal evap coil had rusted where pieces started to block the line at the exit from the house. Evap coils are all aluminum these days so no worries in that department.
IMO the biggest adjustment you'll have is during the shoulder season (Spring/Fall) where it's not cold/warm enough to run the HVAC but the humidity is still high.
https://weatherspark.com/compare/y/...age-Weather-in-Fargo-Williston-and-Birmingham
Meaning insulation on the pipes inside the "box" and anything exposed. One more pro tip: When people in Alabama say LA, they mean Lower Alabama, not Los Angeles.
Just moved in today. Love the home, but getting used to the heat and humidity. Might need to do a mini split for the garage because it was sweltering!
Termite bonds...are they worth it? I'm due for a treatment by the looks of it in about a month. No termites in ND, so this is a new one for me too.
  • Like
Reactions: GON
