Source of Potassium in air cooled engine UOA?
Indiana (IN)
I have a Harley Sportster 1200 air cooled engine. My three used oil analysis have all had 11-22 ppm of potassium, I don't know where it could come from as there is no coolant.
I've used three oils, HD 360, HD SYN3 and Red Line MC all in 20w-50.
I do run Red Line SI1 fuel injector cleaner (1 - 2 oz per 4.5 gallon fill about once a month) and mostly Shell VP 93 gasoline.
Any Ideas?
Potassium is an additive.
It could be a potassium tri-borate AW/EP additive and or part of the detergent/dispersant agents.
What does the VOA of this oil show?
A VOA of the Harley HD360 showed 3 ppm Potassium. Three others of SYN3 showed no Potassium.
I didn't do a VOA of the Red Line MC 20w-50.
Some ester based oils like Red Line use a stable dispersion of nanoparticulate potassium borate that acts as a friction modifier and a mild corrosion inhibitor.
If this additive attaches itself to metal does it mean that a used oil analysis is not useful in establishing the potassium level in the engine and may not relate to levels in a VOA?
Originally Posted By: ExMachina
A little gets in to the oil via the air filter past the rings. Airborne dirt dust.
No, that is silicon. Most dirt and dust is composed of silicates.
