Harley and Mobil 1 5000 miles with particle count
Indiana (IN)
2013 Sportster XL1200C, motor is still stock.
I ran the Harley standard Sportster 63805-80A and Mobil 1 M1MC-131 filters for 5000 miles each using Red Line MC 20w-50.
Riding was pretty much the same for each. All used oil analysis by Blackstone.
Mobil 1 filter hotline told me the M1MC-131 was rated at 10 microns (up to 99.9%)
https://mobiloil.com/en/oil-filters/motorcycle-oil-filters
Copper is still too high but has been moving down, it was 190 at 1022 miles with HD 360 20w-50 factory fill, 278 at the 5000 mile UOA. (4000 miles on HD SYN3 20w-50)
It was 263 at the 10,000 mile UOA 5000 miles on Red Line MC 20w-50. No particle counts on any of those used oil analysis, all with the std HD filter.
The Mobil 1 filter did much better at 4 and 6 microns but not any better at the larger sizes.
The wear metals except copper are all below the 2500 mile universal average even though I ran the oil 5000 miles.
I am running the Mobil 1 filter again. I will probably try the HD Superpremium5 filter on the next change.
Sql Query:
| Miles on oil | 5000 | 5000 |
| Total miles | 15000 | 20000 |
| Date | 02/20/16 | 10/12/16 |
| Make up oil | 0 | 0 |
| Oil Brand | Red Line MC | Red Line MC |
| Weight | 20w-50 | 20w-50 |
| Filter | HD B | M1 MC131 |
| ALUMINUM | 3 | 1 |
| CHROMIUM | 0 | 0 |
| IRON | 8 | 5 |
| COPPER | 132 | 75 |
| LEAD | 4 | 1 |
| TIN | 9 | 3 |
| MOLYBDENUM | 456 | 403 |
| NICKEL | 1 | 0 |
| MANGANESE | 0 | 0 |
| SILVER | 0 | 1 |
| TITANIUM | 0 | 0 |
| POTASSIUM | 7 | 4 |
| BORON | 15 | 13 |
| SILICON | 10 | 8 |
| SODIUM | 7 | 10 |
| CALCIUM | 2703 | 2214 |
| MAGNESIUM | 45 | 16 |
| PHOSPHORUS | 1676 | 1516 |
| ZINC | 2315 | 1811 |
| BARIUM | 3 | 3 |
| SUS @ 210F | 98.8 | 103.9 |
| cSt @ 100C | 20.08 | 21.26 |
| Flashpoint F | 430 | 420 |
| Fuel % |
| Antifreeze % | 0 | 0 |
| Water % | 0 | 0 |
| Insolubles % | 0.2 | tr |
| TBN | | |
| ISO Code (2) | 21/14 | 18/14 |
| NAS 1638 Class | 12 | 10 |
| ISO Code (3) | 24/21/14 | 24/18/14 |
| SAE AS4059 cpc | 12 | 12 |
| 4 Micron | 122237 | 85538 |
| 6 Micron | 18446 | 2430 |
| 14 Micron | 97 | 117 |
| 21 Micron | 23 | 22 |
| 38 Micron | 3 | 2 |
| 70 Micron | 0 | 0 |
I keep the data in an Excel spreadsheet and used this link to do the formatting above. Copied the cells from Excel and pasted into the INput. I just copied the output table from the web page and put it in "Code" tags.
https://senseful.github.io/web-tools/text-table/
