OVERKILL
$100 Site Donor 2021
Absolutely fine, as I said, I was just pointing out that the quote in the OP was focusing on finished lubes, not bases specifically. I welcome a discussion about the bases themselves however!Correct. I admit that I started the post early this morning that actually had to work and got distracted. But I think I was meandering into something a bit more wholistic regarding GTL overall, perhaps mainly SOPUS.
Just speculation on my part, but it may be just how they blend the GTL bases. Back when they were first introduced (they may have more now), this was the slate:It seems their North American oils all use at least a majority of GTL yet they have several lines of the typical "Good, Better, Best, & Extremely Bestist!"
What I'd really like to know is what is the difference between Shell Rotella Gas Truck and the base Pennzoil synthetic vs. Platinum and and Ultra Plat. And Quaker State Synthetic. All have pretty low pour points and seem to perform well in certifications and look similar in PDS. But is there a tangible difference in some GTL "Group III+" oils as far as how they are hydrocracked? Or do they just add more Ester to the higher level oils like Ultra?
That's really kind of where I wanted to go, because it seems like there are very real differences even within GTL where some are on par with say VISOM and others might be pretty close to top PAO in performance...
The Noack on that 8cSt is quite impressive! This was back when we had Ultra 5w30 introduced with its jaw-dropping low Noack of 6.6%. They then seemed to back away from the insanely low Noack oils (and changed-up the product offerings) and then stopped sharing Noack with us on PD sheets.
Of course we can't ignore that they likely have access to AN's through XOM, and I know that @Rod Knock was speculating that perhaps SOPUS is using XOM AN's in some of their higher tier finished lubes. If they were doing that instead of lower group bases to improve solubility, it might explain the artifacts you are seeing. Per that quote that @930.engineering made above, GTL is dry like PAO (though not as bad) so it needs help with solubility too. This is typically done using lower group "carrier" oils but it can also be achieved with POE and AN's. There wouldn't be need for POE with Group III, but AN's could definitely work to "polish" the combo, if we are making some somewhat educated guesses with regards to what is going on.
