Theoretically, given that the majority of the top billet blocks for racing are solid - e.g. no provisions for water cooling, I was wondering about the stability of a given motor oil in this sort of environment over a greater period of time than a 1/4 mile, say a 6 hour endurance race.
I'm currently laying out the plans for an endurance build - chassis hasn't been decided upon - though the Honda S2000 is the closest contender right now. The current motor plan is as follows:
- BBC (5 inch bore space), solid billet block (CN Blocks)
- 8000 RPM max
- Dry sump (24 quart capacity)
- Dual inline single pass oil coolers (~14 - 18" in length/ each)
- Methanol fuel (0.6 - 0.8 lambda)
- 50wt - 70wt oil (mono grades)
- Mechanical Fuel Injection (Enderle)
Given that methanol offers a relatively substantial cooling effect (e.g. latent heat of vaporization), a rather large oil capacity (24 quarts), and dual oil coolers. If the oil temperatures are kept below 240f, would this be sufficient enough to prevent the oil from shearing/ coking, in turn, allowing the engine to run said endurance event - sans water cooling?
- 8000 RPM max
