Solid Block - sans water cooling
ON - Canada
Theoretically, given that the majority of the top billet blocks for racing are solid - e.g. no provisions for water cooling, I was wondering about the stability of a given motor oil in this sort of environment over a greater period of time than a 1/4 mile, say a 6 hour endurance race.
I'm currently laying out the plans for an endurance build - chassis hasn't been decided upon - though the Honda S2000 is the closest contender right now. The current motor plan is as follows:
- BBC (5 inch bore space), solid billet block (CN Blocks)
- 8000 RPM max
- Dry sump (24 quart capacity)
- Dual inline single pass oil coolers (~14 - 18" in length/ each)
- Methanol fuel (0.6 - 0.8 lambda)
- 50wt - 70wt oil (mono grades)
- Mechanical Fuel Injection (Enderle)
Given that methanol offers a relatively substantial cooling effect (e.g. latent heat of vaporization), a rather large oil capacity (24 quarts), and dual oil coolers. If the oil temperatures are kept below 240f, would this be sufficient enough to prevent the oil from shearing/ coking, in turn, allowing the engine to run said endurance event - sans water cooling?
Umm, you do know VW and Porsche built plenty of engines with no provisions for water cooling? Maybe examine their proven designs instead of trying to reinvent one.
Solid blocks are for drag racing or tractor pulling.
No water in the cylinder heads? Forget it. Meltdown will occur within 3 minutes under power.
And if you plan to do "internal cooling" by flooding the engine with excess amounts of methanol, fuel dilution of the oil will be a bigger issue than shearing or coking.
(And not to mention high ring and bore wear from flooding the cylinders with methanol.)
Yea, not gonna happen. Solid blocks will never have a place outside of 1/4 mile passes. 8k RPM in a BBC for 6 hours will be tough enough with properly functioning water cooled blocks.
