What happens when you mix sodium with water ?
That depends, Merk, and that's why we have to watch your little "trolling" threads.
If you want to know what happens when you mix sodium with water, go to your local university, get a block of sodium, and throw it in the toilet. Stand back when you do it, by the way.
If you're talking about mixing sodium salt into water, as in sodium chloride, it will dissolve into an ionic solution, and, you'll have salt water. Yes, it can be conducive to corrosion, it is conductive, and doesn't taste great.
None of this, however, matters. The sodium in an oil's additive package is neither elemental sodium nor sodium chloride, so neither of these things will happen if moisture gets into your engine.
Don't let Mola read this thread or he'll spit his coffee all over his monitor. SonofJoe probably did so already with his tea.
madeej11: This is BITOG, so people occasionally discuss their oil stashes, which is quite on topic here, and of interest to many other users. We even have threads dedicated to showing pictures of oil stashes. I've posted in those threads and read all about people's stashes, too.
