So what actually is the best small engine oil?
What I use and all my mowers are a few decades old...
I mean if this is the oil they run in 100k top fuel engines making 10,000 hp, it ought to give any air cooled vtwin the ultimate protection. Haven't posted in a while and figured this would be a good starter.
I absolutely love Maxima oils for my motorcycles but for my aircooled engines I have always run a full synthetic 5w-40 or 5w-50 depending on the engine.
My zero turn kawasaki runs hard and hot and I run schaeffers s9000 5w-50 leftover from a motorcycle trial. It didn't shift well, so I stopped using it and had a few gallons leftover.
Generators, power washers, chipper, push mower etc get Mobil 1 Turbo Diesel Truck 5w40 or rotella T6.
For the price I don't think a good HDEO can be beat. I always go with synthetic to help fight coking and sludging from the heat of aircooled engines.
I don't think I have actually purchased or used a conventional oil in decades. No reason when synthetic is only a few dollars more.
0W-40 here. If it’s good enough for Porsche with A40 approval it’s good enough for my lawn mower and other OPE including my generator. If it were extremely hot I’d use 15W-50.
Same. Mobil 1 FS 0W-40 for everything including my CR-V, although I am giving ESP 0W-30 a long spin in it until what I stocked up on runs out.
You running in 100f temps
The important question is - what is the engine oil temp when that happens. It may be a lot lower than you think.
I wouldn't say so. My kohler command is a 1000cc 40hp engine that works hard on my exmark in 100⁰+ texas heat. All engines pretty much work the same way. They all use oil as a coolant and a lubricant. IMHO small engines work harder and would benefit from better protection. My exmark has 1650 hrs on it and the hydros are commercial parker units and have a small capacity compared to hydrogear systems. Ive ran nothing but motul 300v 15w50 (group 5 ester) changed every 500hrs and the fluid comes out looking brand new. Ive serviced several identical machines to mine and the hydro oil was burnt or had a burnt smell. But of course I dont abuse my machine near as much as a lawn care worker would abuse the employers equiment.
I see more Exmarks doing commercial mowing than any other brand. I assume they have satisfied owners and the word gets around. (I bought a Ferris because of the suspension system).
I damaged a nice Honda mower with synthetic 5-30, M1 actually. Grass was always thick and wet and mowing weekly it was bogging hard and ran hard. I live in the south where it’s hot. It made silver filings, developed startup smoke. Switched to 10-30, the silver filings stopped, and while startup smoke continued, it stopped getting worse.
It was a significant difference for that mower under these conditions between 5-30 and 10-30.
I usually ran whatever I had in the garage. My truck takes 8 quarts and my rider takes 2, so I've been running Restore and Protect 5w-30 in my rider since I always had 2 quarts leftover from my truck oil changes.
But on a whim last week I filled the rider with Valvoline VR1 10w-30 and it sure feels like it's running more smoothly now.
Rider is a 54" Husqvarna with a 24hp B&S Intek motor and I mow several acres at a time.
