So what actually is the best small engine oil?
I tried to pull-start my generator when it was -5 degrees with 10W-30 in it, and it was really hard to pull thought I was going to break the cord. Drained the10W-30 out after the power came back, refilled with 0W-40, it pulled a lot bettera few days later a 0 and I never used anything else. It has been used for days at a time, winter and summer. 0W-40 or 0W-30 for peace of mind.
Many generator manufacturers recommend a 5W for cold starts 32 below I don't see an issue with your choice. Modern Generacs use 5W20 year round they're living dangerously or what lol?
SuperTech Blend 10w-40 in all my OPE. After Hurricane Matthew my 8500 KW generator ran 24/7 for two weeks straight while the house was being put back together. Had to keep the two freezers and a fridge running. The only time it didn't run was when I filled up with gas after a days work, around 9pm, and went to my daughters house where we were living. I'm guessing it ran out of gas around 7am.
The generator survived fine But not the food. Turns out we had to pitch all the food we were trying to save ($).
Its all about your ambient operating temperatures. 0w bottom number in northern climates for easy winter starting, southern temps at least a 10w bottom number for hot weather.
For the small amount of oil needed use a full synth. oil and change it regularly.
My 30 yr. old Briggs are still churning away just fine with oil and air filter servicing. As well as my Tecumseh flat head snowblowers.
Stabilize your fuels for even less issues. I keep my gas cans stabilized year 'round, even with E0.
When its time to go I want it to go without problems.
That was my maintenance regimen back in NY. Old yard machine snowblower with a 5hp Tecumseh. Would Start 1st pull every single time cold hot and out of storage. electric start was nice at 3am though lol.
I mean if this is the oil they run in 100k top fuel engines making 10,000 hp, it ought to give any air cooled vtwin the ultimate protection. Haven't posted in a while and figured this would be a good starter.
Proper lubrication occurs at an oil viscosity of around 10cSt.
Most engines run at around 100c usually + or - 10c and at 30wt oil is perfect.
I only run 20w-50 oil in engines doing things that drive the temperature well above 110c.
Such as my riding lawn mower, pressure washer and my fixed speed generators. Generators need 40wt oil the way I run them, but I'll put 20w-50 if I don't happen to have an S series oil in 40wt on hand. But a 30wt oil is fine during the winter as they run a lot cooler when it's below freezing, also pull starting gets much more difficult below freezing when there's 20w-50 in the crank case.
Run M1 15W50 FS for 4-stroke B&S mower and motorcycle. Only used late Spring through early Fall so temps are in the mild to hot range. All good after many years.
Past two winters I used Mobil1 EP 5W30 in the oil sump . I added two tables spoons of Militec1. Has purred like a kitten. Briggs and Stratton small motor. Not much oil in sump when servicing
