But it IS a matter of the base oil type, that's why carrier oils are used for the additive package because PAO and Group III, regardless of the viscosity, have poor solvency. Pointing out that Yubase 4 has better solvency than Yubase 8 is like pointing out that .223 has lower penetration than 5.56mm, ignoring the fact that the difference is so minute that it's immaterial. They both suck.
They all suck, all the PAO's, it doesn't matter which one you are looking at, hyper-focusing on the aniline point and ignoring this fact is bordering on trolling. That's why oils leveraging PAO as the primary base will use AN's and or Esters to not only deal with the seal shrink issue, but also add sufficiency solvency.
Again, Group III solvency is extremely poor, this is why carrier oils are used, to provide sufficiency solvency for the additive package and sometimes we STILL see settling out in the finished product, like with certain Shell products. This is also why your typical ILSAC oils, blended to a price point, are not good at cleaning. You need something highly polar, or with good solvency (esters or AN's) to actually solve deposits.
Important to note:
There is a huge spectrum of 0W-20's on the market ranging from minimal VII content to considerable VII content and this can be inferred from the VI of the finished product. If you've got two 0W-20 and one has a VI of 160 and the other one 212, you can be certain that the one with the higher VI has considerably higher VII content and lower viscosity base oils. This is very common with the Japanese OE 0W-20's like TGMO.
Here's a relatively low VI 0W-20 blended with Yubase, has 6.2% OCP VII. Note the 0W-30 has 9.2% VM:
Here are a number of them with VII content of 7.0%, also employing Yubase:
And another Yubase 0W-30, this time with 10% VM:
Here are some XOM examples, now note the 0W-30 has much lower VII content than the Yubase one, and the 0W-40 has lower VM content than the above Yubase 0W-30:
