Quote:
There is no unfiltered oil coming through the gap between the end cap and the center tube, the gap between the center tube and end cap is harmless......
I don't see it that way.
The endcaps as designed must completely cover the ends (both) of the centertube the over complete circumference of the centertube for the entire fci or unfiltered oil can/will bypass at that point. Each picture shows the potential bypass area.
In the first pic the area is between 3 and 4 o'clock. In pics two and three the filter has been rotated and that area is at the 12 o'clock position, especially visible in pic 3. And it should be noted that the view is only from one end (adbv/base) and of an unused filter where the pleats have not had the opportunity to distort or pull on the fiber endcap.
If the gap between the centertube and endcap is "harmless", then imo the same could be made of some of the tears seen in some Puro's posted here. The result is the same, some bypass of unfiltered oil. The difference is the tears can generally be more easily seen, the centertube fiber endcap area may not be seen until the adbv and/or the leaf spring/bypass has been removed and requires careful observation of those areas and knowing what to look for.
So I'll agree to disagree with your conclusion. And completely agree with edhackett's points and conclusion he made while referencing a similar area on Brian Barnhart's earlier dissection pics. Again quoting Ed for clarity.
Originally Posted By: edhackett
Your second picture down shows why I will not use a fiber end cap Fram. At the 4:30 position you can see that the center tube is misaligned. This compromises the seal at that point. I've seen pictures and had one personally where the pleats had buckled and the end caps pulled down enough to show a definite leak at the bypass end. Some off center tubes don't seem to cause a problem and the marks from the ADBV or bypass piece show the seal may have been OK, some show the seal clearly compromised......
Ed
Thanks for the pics and re-illustrating Ed's points.
